RoundRound
Oct 26, 2021Aspirant
Wifi speed drop when go through satellite
I am using RBR40. When only the router is on, at the position of the satellite(which is off), the speed via wifi is like 1xx Mbps. However, with the satellite on, I ran the speed test again near the s...
Oct 26, 2021Guru - Experienced User
Be sure your wifi device is connected at the RBS before testing. If you move near the RBS, this doesn't mean that the wifi device will stop it's connection to the RBR and connect to the RBS. Some devices don't have good roaming features. So you have to disable the wifi radio temporarily on the device, move to near the RBS then re-enable the devices wifi radio and then it should connect to the RBS.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter.
RoundRound
Sure it is connected to satellite, and the speed drop significantly.(30 Mbps)
At the position of satellite, connected to router, 1xx Mbps
Why going through satellite would cause the speed to drop?
- RoundRoundOct 26, 2021AspirantWith the wifi speed from router 1xxMbps (position A), I expect that if I place the satellite at position A, it will extend the wifi with this speed to its nearby position, but obviously it is not the case
- FURRYe38Oct 26, 2021Guru - Experienced User
Please provide feedback on the questions presented and try some of the suggestions.
