RoundRound
Oct 26, 2021Aspirant
Wifi speed drop when go through satellite
I am using RBR40. When only the router is on, at the position of the satellite(which is off), the speed via wifi is like 1xx Mbps. However, with the satellite on, I ran the speed test again near the s...
RoundRound
Sure it is connected to satellite, and the speed drop significantly.(30 Mbps)
At the position of satellite, connected to router, 1xx Mbps
Why going through satellite would cause the speed to drop?
RoundRound
With the wifi speed from router 1xxMbps (position A), I expect that if I place the satellite at position A, it will extend the wifi with this speed to its nearby position, but obviously it is not the case
- FURRYe38Oct 26, 2021Guru - Experienced User
Please provide feedback on the questions presented and try some of the suggestions.
