Sanketh
Mar 28, 2018Aspirant
Wifi Speed Issues on Orbi AC3000
Hi All, I recently bought Orbi AC3000 Tri Band for my house. I previously had google wifi but moved over to Orbi as friends suggested higher throughout. I have a 1gb comcast line- With ethernet c...
Mar 28, 2018Guru - Experienced User
Are you testing with a ethernet connected PC with the Orbi. Don't use wireless. Wireless speeds on client side hw varies and some device don't support 900+- speeds. You'll need to check with the devices Mfr to see what actual thruput speeds they support. Most mobile devices don't support much over 400-500Mb.
What FW are you using on the Orbi?
- SankethMar 28, 2018Aspirant
Hello- I am tested with Ethernet cable connect to Dell PC. Sorry- I am a rookie in terms of terminology- Can you please tell me what MFR stands for?
My Setup: Arris sb8200)>Orbi AC3000>Mac book pro or iOS.
Please let me know if there is a trouble shooting steps I can follow
- FURRYe38Mar 28, 2018Guru - Experienced User
Mfr=Manufacturer
Does the Mac have ethernet support? if it does, try testing with that. Most wifi on Mac or mobile devices won't see those higher speeds.
Hello-
My mac does not have an ethernet port unfortunately. Is there anyway I can change the band width to 5ghz only? Also, thank you for the clear explanation about IOS.
