Sanketh
Mar 28, 2018Aspirant
Wifi Speed Issues on Orbi AC3000
Hi All, I recently bought Orbi AC3000 Tri Band for my house. I previously had google wifi but moved over to Orbi as friends suggested higher throughout. I have a 1gb comcast line- With ethernet c...
Mar 28, 2018Guru - Experienced User
:smileywink:
- guzzijasonMar 28, 2018Apprentice
The best you can realisticly hope to achieve over WiFI with the Orbi is in the ballpark of 500-600 Mbps, and that will vary depending on how "clean" your WiFi environment is. It also assumed there are no upstream bottlenecks.
- SankethMar 28, 2018Aspirant
Is that because of Orbi Limitations or something to do with the Modem?
