Sanketh
Mar 28, 2018Aspirant
Wifi Speed Issues on Orbi AC3000
Hi All, I recently bought Orbi AC3000 Tri Band for my house. I previously had google wifi but moved over to Orbi as friends suggested higher throughout. I have a 1gb comcast line- With ethernet c...
Mar 28, 2018Guru - Experienced User
Limitations of the client wifi HW.
guzzijason
Mar 28, 2018Apprentice
For reference:
https://kb.netgear.com/31211/At-what-speed-and-bandwidth-can-my-Orbi-system-transmit-data
These are theoretical limits based on the Orbi radio configuration. Your actual speeds will be less than this, whis is perfectly normal.
