limited733
Jun 03, 2019Follower
Wifi Speed problem Orbi AC300
Hello everybody, I own this system for about 3 weeks and is installed in my apartment with 135qm2. Provider is Unitymedia(here in Germany) with 400mbit / s. The speed is very unstable at the same ...
Jun 03, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Depending upon wireless devices, some speeds may vary and may top out at 400Mb. Thats a limiation of some wireless devices.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
limited733 wrote:
Hello everybody,
I own this system for about 3 weeks and is installed in my apartment with 135qm2. Provider is Unitymedia(here in Germany) with 400mbit / s. The speed is very unstable at the same place of measurement via Ookla. Sometimes i see 400mbit / s over WLAN and other times of max. 100mbit / s, although if one connects a PC directly over Ethernet cable with the Unitymedia modem values of approx. 420mbit / s are shown. Does anyone know what this may be and how to optimize the wireless speed? Thank you in advance for any answer.
