Bugs3775
Dec 05, 2019Aspirant
WiFi speed slower then other routers
I’m on my note 10+. Right on the other side of my bedroom wall. Less then 10 feet from Orbi. 650 mb WiFi sped only. All other routers my note 10+ is at 866mb. What’s wrong? Is the Orbi that bad? ...
- Dec 09, 2019
I returned the router so I don’t have it anymore.
Dec 06, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Bugs3775Dec 06, 2019AspirantThanks a lot.
Newest firmware. Mouthwash it’s ok now. The Orbi shows 866mb to the note 10+ now. Weird.
I’m less then 10 feet from the Orbi.- Bugs3775Dec 06, 2019AspirantStupid auto correct. Not mouthwash but I said but it’s ok.
- FURRYe38Dec 08, 2019Guru - Experienced User
LOL, ok, glad it's working now. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
- Bugs3775Dec 09, 2019Aspirant
