JeffDo
May 11, 2018Aspirant
Wifi Speed Stuck at 30MBPS on Orbi
Hey all,
For a long time I have been enjoying the Orbi's wifi system. I have up to 400MBPS download speed purchased, and I have been at that speed for a long time until now. Now, when I test the wi...
JeffDo
May 12, 2018Aspirant
Update: I've noticed that whenever my computer is using the internet via the satellites, the speed is only stuck at 30mbps, but whenever I use wifi or ethernet for the actual router, the speed is normal.
- cscheieneMay 12, 2018StarIs it only for that computer the speed gets throttled?
- UlairiMay 12, 2018Luminary
You’re problem may be different then.Try different combinations of Ethernet cables, which port you’re using on the Sat and if possible a different test PC, to eliminate variables in the test environment. If that doesn’change anything then a factory reset is the next obvious step. A factory reset, as painful as it is to set up everything again, works for a number of glitches, including bottlenecks.
Note that the link I gave earlier was for the RBK50 firmware. Make sure you’re running the most up to date firmware off your kit’s support (download) page.
