JeffDo
May 11, 2018Aspirant
Wifi Speed Stuck at 30MBPS on Orbi
Hey all,
For a long time I have been enjoying the Orbi's wifi system. I have up to 400MBPS download speed purchased, and I have been at that speed for a long time until now. Now, when I test the wi...
JeffDo
May 12, 2018Aspirant
Update: I've noticed that whenever my computer is using the internet via the satellites, the speed is only stuck at 30mbps, but whenever I use wifi or ethernet for the actual router, the speed is normal.
Ulairi
May 12, 2018Luminary
You’re problem may be different then.
Try different combinations of Ethernet cables, which port you’re using on the Sat and if possible a different test PC, to eliminate variables in the test environment. If that doesn’change anything then a factory reset is the next obvious step. A factory reset, as painful as it is to set up everything again, works for a number of glitches, including bottlenecks.
Note that the link I gave earlier was for the RBK50 firmware. Make sure you’re running the most up to date firmware off your kit’s support (download) page.
