cix
Sep 14, 2020Aspirant
wifi speed
Hello all, i bought ORBI RBK 53, and i have optical internet 100Mb/s, when i do speed test in Ookla, or another app i get 100Mb/s in download and 20Mb/s in upload, but when i go on my Orbi Netgear ap...
Mstrbig
Sep 14, 2020Master
cix wrote:Hello all, i bought ORBI RBK 53, and i have optical internet 100Mb/s, when i do speed test in Ookla, or another app i get 100Mb/s in download and 20Mb/s in upload, but when i go on my Orbi Netgear app, and i do speed test there i get 50Mb/s Download, and 20Mb/s Upload. Is this maybe because of the netgear server, and do i have now 100Mb/s or 50Mb/s.
Thanx for the help
Who is your ISP and what equipment did they provide?
What is the current firmware on your Orbi device?
What device is your Orbi router connected to?
Did you reboot your ISP modem/router, before starting the Orbi router install?
Have you changed the network cable connected from the ISP device to your Orbi router?
Are your satellites wired or wireless?
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence. Enable WMM, Implicit BeamForming, Mu-MIMO, Set Short preamble mode. Save settings, reboot Orbi.
cix
Sep 15, 2020Aspirant
It's T-com, when i m connected to their router i get 100Mb/s speed all the time.
Firmware 2.5.1.16
Directly from my ISP router to Orbi router, and i did reboot my ISP router.
I used the cable that i got with Orbi router.
Sattelites are connected wireless.
I will try all this that you wrote.
Thank you very much
Firmware 2.5.1.16
Thank you very much
