thejs
Apr 05, 2018Aspirant
Wifi speeds below 20 mbps on RBR50
I have had the Orbi router since September 2017. It never once failed me, until 3 days ago I started noticing slow internet speeds. I assumed it was my ISP, so I connect my laptop to the modem using ...
Apr 05, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem?
What ISP Speeds do you pay for UP and Down?
Any other wifi neighbors near by? If so, how many?
What channels are you using?
What wireless devices are you using for speed testing. Wired speed testing is preferred as there are many factors that contribute to inaccurate speed testing over wireless.
- thejsApr 05, 2018Aspirant
The ISP modem is a Technicolor, model TC4350.
I have 150 Mbps DOWN and 15 Mbps UP.
There are three other WiFi networks, and this has been the case since I bought these routers.
I am using Auto on 2.4GHz and 48 on 5GHz (I never changed them, these were set automatically)
I did three tests using an ethernet cable, I ran a test on my modem, ORBI router and Satellite and they all gave me close results. I ran these test on a Lenovo and MacBook Pro. I then ran speed test using the Wifi on both computers and the results were slow.
I am attaching the speed test screenshots that i ran using a cable connected to the Satellite, as well as the results I ran using my MacBook Pro using WiFi.
I used Google speed test, speedof.me, speedtest.net and fast.com
Thanks for replying.
- FURRYe38Apr 05, 2018Guru - Experienced User
Ok, Just checking to make sure the modem doesn't have a router built in.
Try setting 2.4Ghz on 1, 6 or 11. Try 11 first.
I'm using 1, and 48 on my router and consitently get 200/10 speeds on my iPhone 6sP at the router and Satellite. Just ran today. Satellite is wireless connected. Not wired backhaul. Using Beta version of FW, v2.1.3. Factory reset both router and satellite after updating. MIMO is disablied. I don't have Daisy Chain or Fast Roaming, You might try disabling these as well at some point.
Any other kinds of wireless interferences near by?
- thejsApr 06, 2018Aspirant
I tried your settings suggestions and it didn't make any difference. I reset both router and satellite to factory settings and set them up from scratch, changing the SSID and password to make sure my mac was the only connected device, and still I had slow speeds on WiFi and the expected speed connected by ethernet cable on both the router and satellite.
I haven't added any wireless devices or appliances at home that might cause any interference.
I wonder if there is something physically wrong with the routers.
Thanks for trying to help
