techforay
Jan 05, 2023Aspirant
Wifi speeds drop
I have a Orbi RBR50 router with a RBS20 satellite attached. I have a fiber internet provider at 200+ MPS. I get good speeds for a few days through the entire house. Every couple of days my Wifi spe...
techforay
Thats what I thought was happening also but I checked the connections and they were connected to 5g. My current settings for 2.4 is Auto and the 5g is set to 48. I don’t know much about channel selection. Can you help
Jan 05, 2023Guru - Experienced User
usually for 2.4ghz you want channels 1-6-11.
The 5ghz, just try changing to a different channel and see what happens the next time it slows down
- techforayJan 05, 2023Aspirant
Thank you
I set the 2.4 g to 6 and the 5g from 48 to 40. I will see what happens. Thank you very much for your expertise.
I am still getting speed drops but i have learned more. I don’t understand something. I don’t have to reboot the router to get my speed back. I did a speed check on my iphone and was getting 200+. A few hours later i checked it again and was getting 3o mps or less. All i did to get my speed back was turn off wifi on my phone and turning it back on again. Does that help explain anything.
