donpearson
Mar 30, 2019Aspirant
WiFi traffic data
Is their a way for me to setup the traffic data to register the wireless data instead of internet... I use my Orbi in AP mode so it would be a much better use if it then no information at all as it i...
Mar 30, 2019Guru - Experienced User
When in AP mode, most of the management and routing features are disabled. You would have to find some management features on your main host router to see if anything there fits what your looking for.
- donpearsonMar 30, 2019AspirantI know most of the stuff is disabled in AP mode.
I’m not looking for a way to use a third party device, I’m hoping there’s a way for Netgear to sort it out or a hack somehow- FURRYe38Mar 30, 2019Guru - Experienced User
When i AP mode those features are disabled since they require the use of the router mode and WAN Port. When in router mode TM would be enabled. NG doesn't support TM being used in AP mode. IT's not technically feasable.
- donpearsonMar 30, 2019AspirantOf course it’s technically possible to show WiFi traffic data instead of internet traffic data.
