aallred
Dec 19, 2019Aspirant
WIFI Turning on and off several times a day
I have had my Orbi for several years and it has worked great. However, the last month or so, it won't stay connected. It probably disconnects at least 20 times a day. I am constantly reconnecting ...
Dec 20, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
aallred wrote:I have had my Orbi for several years and it has worked great. However, the last month or so, it won't stay connected. It probably disconnects at least 20 times a day. I am constantly reconnecting to wifi during the day. I have checked with my internet provider and I have a great signal, I have unplugged the power for 30 sec and then plugged it back in. Any suggestions?
