godseesad
Jul 12, 2017Tutor
wifi upload speed, ping value are strange
I use R8000 before, the download speed and upload speed is normal 150Mb/150Mb(down/up) ping time under 5ms, but i change to orbi, i use my new ipad, iphone 6s and iphone 6 plus to test the speed, the...
DarrenM
Jul 13, 2017Sr. NETGEAR Moderator
Hello godseesad
Make sure you have the latest firmware you also may want to change the wireless channels see if that improves your wireless connection.
DarrenM
- godseesadJul 14, 2017Tutor
different versions of firmware, same result !
different channels, same result !
enable or disable MU-MIMO, same result !
enable or disable BEAMFORMING, same result !
factory reset n times, same result !
I spend 4XX to buy this one, very disappointed !!! :smileysad::smileysad::smileysad:
