godseesad
Jul 12, 2017Tutor
wifi upload speed, ping value are strange
I use R8000 before, the download speed and upload speed is normal 150Mb/150Mb(down/up) ping time under 5ms, but i change to orbi, i use my new ipad, iphone 6s and iphone 6 plus to test the speed, the...
DarrenM
Jul 13, 2017Sr. NETGEAR Moderator
Hello godseesad
Make sure you have the latest firmware you also may want to change the wireless channels see if that improves your wireless connection.
DarrenM
godseesad
Jul 14, 2017Tutor
different versions of firmware, same result !
different channels, same result !
enable or disable MU-MIMO, same result !
enable or disable BEAMFORMING, same result !
factory reset n times, same result !
I spend 4XX to buy this one, very disappointed !!! :smileysad::smileysad::smileysad:
- DarrenMJul 17, 2017Sr. NETGEAR Moderator
Hello godseesad
Have you gone straight to the modem and ran some tests to make sure the modem if giving the correct upload?
DarrenM- godseesadJul 20, 2017Tutor
Only the IOS devices have this problem ! my laptop and desktop is normal !
- DarrenMJul 20, 2017Sr. NETGEAR Moderator
last thing you could try is back up your routers config and then factory reset the unit as the last firmware was a huge update and then test your IOS devices before loading your config back on the unit.
DarrenM
