dinokath
Jun 09, 2020Star
WiFi with No Internet Connection After FW Update
Morning all, SInce I updated the firmware to 2.5.1.16 from 2.5.1.8, I am having an issue with Wifi being connected but no internet being available. To compound the issue, I get the message of 'Co...
- Jun 10, 2020
Update as of this moment - installed Firefox (weird it wouldn't work with Chrome!) and was able to roll the firmware back on both the RBR and the RBS to the previous version, which is 2.5.1.8.
Did this around 1600 yesterday afternoon and as of 0930 this morning nothing has dropped the internet connection. Fingers crossed but I feel good that perhaps this did the trick because it would drop multiple times per hour, every hour, for the last couple weeks. Seemed to be the biggest problem on the Samsung S10E and my Androiud HiSense TV (maybe it is a conflict with the Android OS??) and now that I say that out loud, this happened on Android devices. Hmmm....
BretD Noticed you are an admin on this forum. Perhaps you could pass along my experience with this firmware update to Netgear Support. Thanks!
Jun 09, 2020Guru - Experienced User
Please try a factory reset and setup from scratch with the RBR and RBS.
Power OFF the ISP Modem for 30 seconds then back on. Walk thru the setup wizard on the RBR.
dinokath wrote:Morning all,
SInce I updated the firmware to 2.5.1.16 from 2.5.1.8, I am having an issue with Wifi being connected but no internet being available. To compound the issue, I get the message of 'Connected No Internet' but still have an internet connection. This happens on both 2.4 and 5 bands.To solve the issue, I disconnect from WiFi and reconnect but this shouldn't be the fix.
As best I can tell, this happens only on WiFi. The laptop I am using to type this up is connected to the network via ethernet and I haven't experienced the issue here.My PS4 is also ethernet connected and while I was gaming last night, the TV kept throwing up 'No Internet Connection' messages dialog boxes but the online gaming was uniterrupted.
I am technically inclined but I readily admit that when it comes to networks and their workings, it completely mystifies me. As far as I am concerned it's witchcraft.
Thank you for any help you can provide. It is greatly appreciated!
Some information on my setup:
ATT/Pace 5268AC Modem
- DMZ+ mode set for the RBR50
- IP address is distinct from RBR50
- Both WiFi bands turned off
Orbi Settings
Internet Connection Status
IP Address 76.XXX.X.XXX - Same as modem
Subnet Mask 255.255.252.0 - Same as modem
Default Gateway 76.xxx.xxx.xxx - Same as modem
DHCP Server 172.xx.xx.xx - Modem's IP Address
DNS Server 8.8.8.8 and 8.8.4.4Router Information
Hardware Version RBR50
Firmware Version V2.5.1.16
GUI Language Version V1.0.0.375
Operation Mode Router
LAN Port
MAC Address xx:xx:xx:xx:xx:xx
IP Address 192.168.1.1
DHCP Server OnWireless Settings
2.4GHz Channel - 06
Enable WMM
CTSRTS Threshold 2347
Preamble Mode Automatic
Transmit Power 100%
5GHz Channel - 48
Same Advanced Settings as 2.4
Security - WPA2-PSK (AES)
Enable Daisy Chain Topography - Off - only 1 satellite is attached
Enable Implicit Beamforming - On
Enable MU-MIMO - On
Enable Fast Roaming - On
Internet Setup
No Login Required
Get UP Address from ISP dynamicall - ON
DNS Address - Set to Google DNS servers
MAC AddressUse Default Address
WAN Setup
Everything unchecked except Disable IGMP Proxying
MTU - 1500
NAT Filtering - Secured
LAN Setup
RIP Direction - Both
RIP Version - Disabled
Use Router as DHCP - checked
Advanced Settings
In Router Mode
No Ports Forwarded or Triggered
No Dynamic DNS
No VPN
No Static Routes
No Remote Management
UPnP On - Seems my PS4's IP is listed there in UDP for ports 9308 and 3074
IPv6 - Auto Detect
- Connection Type DHCP
- Get DNS from ISP
- LAN Setup Auto Config
- IPv6 Filtering - Secured
- dinokathJun 09, 2020Star
Sorry, should have said that I have done a factory reset
FURRYe38 wrote:Please try a factory reset and setup from scratch with the RBR and RBS.
Orbi Settings
LAN Port
2.4GHz Channel - 06
Enable WMM
Transmit Power 100%
5GHz Channel - 48
Enable MU-MIMO - On
Internet Setup
No Login Required
WAN Setup
MTU - 1500
LAN Setup
Advanced Settings
In Router Mode
No Dynamic DNS
No VPN
No Static Routes
IPv6 - Auto Detect
- Get DNS from ISP
on both the modem and the router.- FURRYe38Jun 09, 2020Guru - Experienced User
So when walking thru the setup wizard on the RBR with a web browser, does it report any problems getting a connection with the modem?
Did you get up a IP address reservation first for the RBR ON the modem so it's IP address doesn't change and then input this into the modems DMZ+?
Try AP mode on the RBR and disable DMZ+ on the PACE modem. See if the RBR works in AP Mode with the PACE modem. Be sure the modems wifi is fully disabled.
Seem others with various problems with the model modem. Most were resolved by upgrading to the Arris BGW-210 modem.
No, no issues reported when going through the setup, everything connects fine. Yes, the IP address is reserved on the modem's DMZ and doesn't change.
If I do the AP on the RBR, don't I lose the Netgear Armor and the firewall on the Orbi?
If the problem is with the modem, why did it work just fine before the FW update? Tried to roll back the FW update and can do it on the satellite but the router keeps locking up the GUI and resetting the interface.
