dinokath
Jun 09, 2020Star
WiFi with No Internet Connection After FW Update
Morning all, SInce I updated the firmware to 2.5.1.16 from 2.5.1.8, I am having an issue with Wifi being connected but no internet being available. To compound the issue, I get the message of 'Co...
- Jun 10, 2020
Update as of this moment - installed Firefox (weird it wouldn't work with Chrome!) and was able to roll the firmware back on both the RBR and the RBS to the previous version, which is 2.5.1.8.
Did this around 1600 yesterday afternoon and as of 0930 this morning nothing has dropped the internet connection. Fingers crossed but I feel good that perhaps this did the trick because it would drop multiple times per hour, every hour, for the last couple weeks. Seemed to be the biggest problem on the Samsung S10E and my Androiud HiSense TV (maybe it is a conflict with the Android OS??) and now that I say that out loud, this happened on Android devices. Hmmm....
BretD Noticed you are an admin on this forum. Perhaps you could pass along my experience with this firmware update to Netgear Support. Thanks!
JaGresh74
Jun 09, 2020Aspirant
Having exactly the same issues. Tends to drop on WiFi about 11pm each night for almost passed week. We as only when I jumped on an IPAD there was a notification on ORBI app that my firmware updated to 2.5.1.16, six days ago which is about right.
I think this update has caused my issues. It's been great to date and should be for money I paid for the kit.
I've not yet tried a factory reset but sounds like didn't help you?
John
dinokath wrote:Morning all,
SInce I updated the firmware to 2.5.1.16 from 2.5.1.8, I am having an issue with Wifi being connected but no internet being available. To compound the issue, I get the message of 'Connected No Internet' but still have an internet connection. This happens on both 2.4 and 5 bands.To solve the issue, I disconnect from WiFi and reconnect but this shouldn't be the fix.
As best I can tell, this happens only on WiFi. The laptop I am using to type this up is connected to the network via ethernet and I haven't experienced the issue here.My PS4 is also ethernet connected and while I was gaming last night, the TV kept throwing up 'No Internet Connection' messages dialog boxes but the online gaming was uniterrupted.
I am technically inclined but I readily admit that when it comes to networks and their workings, it completely mystifies me. As far as I am concerned it's witchcraft.
Thank you for any help you can provide. It is greatly appreciated!
Some information on my setup:
ATT/Pace 5268AC Modem
- DMZ+ mode set for the RBR50
- IP address is distinct from RBR50
- Both WiFi bands turned off
Orbi Settings
Internet Connection Status
IP Address 76.XXX.X.XXX - Same as modem
Subnet Mask 255.255.252.0 - Same as modem
Default Gateway 76.xxx.xxx.xxx - Same as modem
DHCP Server 172.xx.xx.xx - Modem's IP Address
DNS Server 8.8.8.8 and 8.8.4.4Router Information
Hardware Version RBR50
Firmware Version V2.5.1.16
GUI Language Version V1.0.0.375
Operation Mode Router
LAN Port
MAC Address xx:xx:xx:xx:xx:xx
IP Address 192.168.1.1
DHCP Server OnWireless Settings
2.4GHz Channel - 06
Enable WMM
CTSRTS Threshold 2347
Preamble Mode Automatic
Transmit Power 100%
5GHz Channel - 48
Same Advanced Settings as 2.4
Security - WPA2-PSK (AES)
Enable Daisy Chain Topography - Off - only 1 satellite is attached
Enable Implicit Beamforming - On
Enable MU-MIMO - On
Enable Fast Roaming - On
Internet Setup
No Login Required
Get UP Address from ISP dynamicall - ON
DNS Address - Set to Google DNS servers
MAC AddressUse Default Address
WAN Setup
Everything unchecked except Disable IGMP Proxying
MTU - 1500
NAT Filtering - Secured
LAN Setup
RIP Direction - Both
RIP Version - Disabled
Use Router as DHCP - checked
Advanced Settings
In Router Mode
No Ports Forwarded or Triggered
No Dynamic DNS
No VPN
No Static Routes
No Remote Management
UPnP On - Seems my PS4's IP is listed there in UDP for ports 9308 and 3074
IPv6 - Auto Detect
- Connection Type DHCP
- Get DNS from ISP
- LAN Setup Auto Config
- IPv6 Filtering - Secured
- FURRYe38Jun 09, 2020Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?Is Armor or Circle enabled on your system?
Please try a reset on yours....
JaGresh74 wrote:Having exactly the same issues. Tends to drop on WiFi about 11pm each night for almost passed week. We as only when I jumped on an IPAD there was a notification on ORBI app that my firmware updated to 2.5.1.16, six days ago which is about right.
- dinokathJun 10, 2020Star
- FURRYe38Jun 10, 2020Guru - Experienced User
I avoid chrome for doing any FW updates.
Wonder why some users are having difficulty with this version of FW, even after a reset and others are not.
