jstampfli's avatar
jstampfli
Wifi works but all other ports do not
I have a good internet connection to the internet but for whatever reason, none of my outgoing ports are working when I directly plug into it. Not sure why that's happening?
  • jstampfli's avatar
    jstampfli
    Jan 12, 2017
    I contacted support and found out the ip address on the satelite was not matching the router.  What I was told to do next is unplug everything coming into the satelite and hold the reset button down for about 1 minute.  Once that was done it hooked up to the router no problem and worked perfectly.
