RO2B's avatar
RO2B
Tutor
Apr 12, 2020
WiFi/wired problem RBK50
So, installed the Orbi after the cable modem (in bridge) with some wired devices. One is a Denon AVR with a static IP. Also different WiFi connecties devices such as Samsung galaxy S10e en IPhone 6s ...
  • FURRYe38's avatar
    Please mark our thread as solved so others will know.
    Enjoy. :smileywink:
    RO2B wrote:
    Problem solved.
    It was a hidden netgear router which causes the problem. I disconnected it and it's all oke now.
    So if you install a new router be asure that all the "old" netgear stuf is out of the wirde network.
