RO2B
Apr 12, 2020Tutor
WiFi/wired problem RBK50
So, installed the Orbi after the cable modem (in bridge) with some wired devices. One is a Denon AVR with a static IP. Also different WiFi connecties devices such as Samsung galaxy S10e en IPhone 6s ...
- Apr 13, 2020
Please mark our thread as solved so others will know.
Enjoy. :smileywink:
RO2B wrote:Problem solved.
It was a hidden netgear router which causes the problem. I disconnected it and it's all oke now.
So if you install a new router be asure that all the "old" netgear stuf is out of the wirde network.
ekhalil
Apr 12, 2020Master
Appreciate it if you can make some clarifications:
- So Orbi is in Router Mode and the ISP router is bridged, right?
- If Orbi in Router mode, what DHCP address range do you have set?
- The Denon AVR is wired to Orbi, right?
- The Denon AVR has a static IP address set on the Denon or in Orbi? What is the static IP address?
- Do you have any DHCP address reservations set in Orbi for the phones?
- I guess your're saying that you're streaming music from the Denon to the phones and music stops when the the phone moves from mobile network (4G) to wifi, is that correct? what is the traffic case please?
RO2B
Apr 12, 2020Tutor
Hi Ekhalil,
Hereby the answers.
YES
standard by orbi: 192.168.1.1 to 192.168.1.248
YES
192.168.1.145
NO
NO, the AVR plays while we are using the HEOS app. So it works through WiFi -> wired network -> AVR (it don’t work with G4). It was working before ORBI (my old WiFi/wired network)
I don’t understand this question.
Hereby the answers.
YES
YES
192.168.1.145
NO
