RO2B
Apr 12, 2020Tutor
WiFi/wired problem RBK50
So, installed the Orbi after the cable modem (in bridge) with some wired devices. One is a Denon AVR with a static IP. Also different WiFi connecties devices such as Samsung galaxy S10e en IPhone 6s ...
- Apr 13, 2020
Please mark our thread as solved so others will know.
Enjoy. :smileywink:
RO2B wrote:Problem solved.
It was a hidden netgear router which causes the problem. I disconnected it and it's all oke now.
So if you install a new router be asure that all the "old" netgear stuf is out of the wirde network.
RO2B
Apr 13, 2020Tutor
Problem solved.
- ekhalilApr 13, 2020Master
Great! Glad to know the issue is solved!
Good luck!
- FURRYe38Apr 13, 2020Guru - Experienced User
Enjoy. :smileywink:
