RO2B
Apr 12, 2020Tutor
WiFi/wired problem RBK50
So, installed the Orbi after the cable modem (in bridge) with some wired devices. One is a Denon AVR with a static IP. Also different WiFi connecties devices such as Samsung galaxy S10e en IPhone 6s ...
- Apr 13, 2020
Please mark our thread as solved so others will know.
Enjoy. :smileywink:
RO2B wrote:Problem solved.
It was a hidden netgear router which causes the problem. I disconnected it and it's all oke now.
So if you install a new router be asure that all the "old" netgear stuf is out of the wirde network.
RO2B
Apr 13, 2020Tutor
Problem solved.
ekhalil
Apr 13, 2020Master
Great! Glad to know the issue is solved!
Good luck!
