ffiori
Apr 23, 2019Aspirant
Will adding AC2200 (RBS20) Satelitte impact overall AC3000 (RBK50) backhaul speed
I know there are many discussions on this topic and I am experiencing similar issues to many. I replaced my existing single multi-antenna router with the RBK50 (Router/Satellite) bundle hoping to ge...
Apr 23, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. I have a orbi at 40 feet distance with just 1 satellite and it works well with great coverage in a 5000sq ft home.
I know you can mix RBS models. I believe the back would not be effected.
- ffioriApr 23, 2019Aspirant
The house is well covered, for the most part. I'm trying to get out to the front of the garage (which is about 30 feet) from main router and I sometimes see the WIFI once in a while. It's off more than it's on, so I must be right at the max limit ditance from the Router. That's why I am trying to add another Satelitte to gain that 10-15 feet, but I don't want to spend another $300/US for an AC300 Satelitte if I don't need to. I don't need supper fast throughput out there, but I don't want to introduce a slower Satelittle in the Mesh either that might cause everything else to slow down.
So if I can put a cheaper Satelitte for the Gargare and not slow things down, I will.
That's the questions: Can I put both AC3000 and AC2200 Satelittes on the same router in a STAR and not impact each other
