ffiori
Apr 23, 2019Aspirant
Will adding AC2200 (RBS20) Satelitte impact overall AC3000 (RBK50) backhaul speed
I know there are many discussions on this topic and I am experiencing similar issues to many. I replaced my existing single multi-antenna router with the RBK50 (Router/Satellite) bundle hoping to ge...
ffiori
The house is well covered, for the most part. I'm trying to get out to the front of the garage (which is about 30 feet) from main router and I sometimes see the WIFI once in a while. It's off more than it's on, so I must be right at the max limit ditance from the Router. That's why I am trying to add another Satelitte to gain that 10-15 feet, but I don't want to spend another $300/US for an AC300 Satelitte if I don't need to. I don't need supper fast throughput out there, but I don't want to introduce a slower Satelittle in the Mesh either that might cause everything else to slow down.
So if I can put a cheaper Satelitte for the Gargare and not slow things down, I will.
That's the questions: Can I put both AC3000 and AC2200 Satelittes on the same router in a STAR and not impact each other
Apr 23, 2019Guru - Experienced User
Yes you can.
- ffioriApr 23, 2019Aspirant
OK thanks will give it a try
- Orbi-RocJun 21, 2019Luminary
Yes he can FURRYe38 , with the caveat that the backhaul speed will be cut in half. Network performance is only as good as the weakest link on the network. So adding an AC2200 to an AC3000 will reduce the backhaul speed 1733Mbps to 833Mbps; and that will slow down the entire network.
I'm personally in the exact same situation; and inasmuch as I want to add another RBS50 to my RBK50 Orbi system, I am offended by Netgear's ridiculous pricing.
