cw12
Dec 05, 2019Aspirant
Will any Orbi satellite work with my RBR50 router?
I have the Orbi RBR50 router and one RBS50 satellite - the Orbi AC3000 pack (RBK50). Now I need to extend the wifi network. Will any Orbi satellite work? Or does it has to be the RBS50? If an...
- Dec 05, 2019
Yes, 50 series carries a 1733Mpbs wireless backhaul support while all others carry a 866Mbps wireless backhauls speed.
I don't believe so, the SRR series is the pro business verson of orbi. I don't believe they are compatible. I would not mix them even if they were.
Dec 05, 2019Guru - Experienced User
Yes. I would recommend keeping with the 50 series RBS to maintain the same backhaul speeds across the the system. Other 20 and 40 series RBS use lower wireless back haul speeds. 1733Mpbs vs 866Mpbs.
cw12
Thanks! So all of them will work, but the RBS50 will perform better?
And what about the Orbi Pro SRS60 Satellite? Will this work too? I guess it has the same speed as the RBS50, right?
- FURRYe38Dec 05, 2019Guru - Experienced User
