cw12's avatar
cw12
Will any Orbi satellite work with my RBR50 router?
I have the Orbi RBR50 router and one RBS50 satellite - the Orbi AC3000 pack (RBK50).   Now I need to extend the wifi network. Will any Orbi satellite work? Or does it has to be the RBS50?   If an...
  • FURRYe38's avatar
    Yes, 50 series carries a 1733Mpbs wireless backhaul support while all others carry a 866Mbps wireless backhauls speed.
    I don't believe so, the SRR series is the pro business verson of orbi. I don't believe they are compatible. I would not mix them even if they were.
