mrstucci1972's avatar
May 20, 2019
Will modem work with my RBR50 & 2 satellites?
Hi I have a RBR50 (I am not sure if it's the 2200 or the 3000) and 2 satellites-one plugs into the wall and the other sits on our dresser.    I just found out about the modem that Orbi has now an...
  • FURRYe38's avatar
    May 21, 2019
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
