emanon
Oct 18, 2019Tutor
Will my cheap Arris modem work great with Orbi RBR20?
I have an ARRIS SBG6700-AC I can use with an Orbi RBR20. Is this a sufficient modem? Or will this modem cause a problem. I'm thinking the specs on the modem does not really matter as long as it allow...
emanon
Oct 19, 2019Tutor
OK thanks for the confirmation! I have previously used the Arris with a Nighthawk R7000 and the Arris was in bridged mode. So I will place it in bridged mode with the Orbi. BTW does it make sense to trade off the R7000 for an Orbi? Will I have a better experience with the Orbi?
michaelkenward
Oct 19, 2019Guru - Experienced User
Depends what you are trying to achieve and what features you want.
I have an R7800 as a front end for an Orbi (in AP mode). The Orbi has better wifi, with its satellites, but the R7800 gives me more control over the router side.
The wifi on the Orbi is AC2200 while on the R7000 it is AC1900, so theoretically faster, although good luck spotting the difference.
