RegDawg
Apr 04, 2018Apprentice
Will Not Factory Reset
All of a sudden today my Orbi router stopped working. After searching it looks like a firmware was inadvertantly released? Well now I can't reset the main router. Sticking a pin in the reset button f...
Apr 04, 2018Guru - Experienced User
Can you access the UI, you can do a factory reset in the routers web page. "Erase" Found under Advanced/Advanced Settings/Backup.
What FW version is loaded on the router?
- RegDawgApr 04, 2018Apprentice
How can I access the UI if I can't connect to its wifi? Hard connection? Right now it doesn't even look like its booting up. The green light on the back is green but not even the LED's blink if I try turn it on/off.
- FURRYe38Apr 04, 2018Guru - Experienced User
Connect ethernet wired PC to the back of the router and see if you can log into 192.168.1.1.
Check the PCs networking settings to see if it's getting an IP address from the router.
Are you sure your feeling the back button push in? Should be a quick bump when you push it in then bump when you let go.
Unfortunately its not getting an IP. Doesn't even feel like its powered on even though the green light is on on the back. Like I said, prior, I would unplug the power and plug it back in and the LED ring would flash. Now it won't even do that.
So I'm probably SOL?
Right now had to plug in an older router (R6300V2) to use for the meantime. This router doesn't give me full coverage in my home.
