sabadir's avatar
sabadir
Will older satellites slow down my ORBI AC3000?
I want to buy a couple more satellites but wow...Netgear is proud of the satellites - surprisingly so since its impossible to get this question answered by people who work there. If I buy one of t...
  • FURRYe38's avatar
    May 13, 2020
    Older? How do you mean? All RBS50 are the same. They all have the same front and backhaul speeds.
    You can add a RBS20 or 30 series to the system and they won't slow the Orbi system down. The backhaul connection rate is lower than the RBS50, 1733 vs 866 so the 20/20 series RBS will just have a slower backhaul connection rate is all.
