petermorlion
Mar 27, 2023Aspirant
Will Orbi 6 work better through walls than Orbi 5?
I currently have an Orbi 5 (RBR50). It works fine in my home, but there is a smaller building separate from my house that needs internet as well. Internet there is spotty. It's never been superb, and...
- Mar 30, 2023
Oh, dear. 2m is "so close" and just screams out for an Ethernet cable between the buildings.
It was a smart move to try PowerLine. As you found out, however, there are serious limitations in that technology.
Would you happen by chance to have cable TV coax that is placed in both buildings? I have used MoCA units with great success.
https://en.wikipedia.org/wiki/Multimedia_over_Coax_Alliance
It was also correct to purchase another satellite. Once you get a network connection from the primary building to the separate structure, having a "real satellite" inside the building will make a dramatic improvement in WiFi.
I would first try moving the satellite to be as close to the primary building as possible.
Some people are fortunate to have windows that face each other.
Those point to point wireless bridges are probably overkill for this situation, being rated for serious distance, which is ironically what sometimes allows them to be mounted indoors. The models that use Power over Ethernet (PoE) solve two problems: (1) getting power to an outside unit (because PoE is "low voltage" and can be run straight through an exterior wall without violating building codes, and (2) gets the network connection through the wall that has been blocking WiFi. In the US, Amazon offers a variety of models at ever price range. New Zealand may not have as many choices.
CrimpOn
Mar 27, 2023Guru - Experienced User
More detail about the physical layout would help.
- is it possible to provide a rough drawing of these buildings, and
- indicate the distances involved?
- Is there a single WiFi access point in one building and the remote building has no access points?
The WiFi Alliance did us no favors when "naming" the various flavors of WiFi.
- WiFi5 introduced the 5GHz frequency band.
- WiFi6 introduced a new method of encoding the same 5GHz frequency band. (802.11ax)
i.e. whatever causes WiFi5 signals to weaken does exactly the same thing to WiFi6 signals. - WiFi6E introduced the 6Ghz frequency band, which is even more affected by distance and building materials than the 5GHz band.
Just replacing the existing WiFi5 system with a WiFi6 system is not likely to be a satisfactory solution.
The most obvious way to provide WiFi to this smaller building is to install an Orbi satellite in the building, or perhaps a WiFi extender.
The devil is in the details.
- petermorlionMar 30, 2023Aspirant
I made a rough sketch, with distances that should be about right (in meter and feet). At the bottom left, the "R" indicates my Orbi router. In the top left of the first building, the "S" indicates a satellite. There is a satellite on the second floor as well, practically above the router.
The distance between the router and the satellite on the drawing is about 14.5m or 47.5 feet. The distance between the two buildings is about 2m or 6.ft.
Now, because I had this problem in the past, I purchased an extra satellite and placed it in the top building, in the top left corner. I had the impression that the satellite had trouble connecting, so I added a powerline-adapter between the two buildings. But like I said, they have their own electrical switchboards so the data has to go through the differential switch, which is what slows it down, from what I read.
