Josephr9
Sep 12, 2019Follower
Will Orbi AC300 work with a C3700 N600 Modem Router?
I have a C3700 N600 Modem Router and would like to add the Orbi AC300 router. Do I need to set up the C3700 as a modem only? Or, can I just connect the Orbi directly to the C3700?
Sep 16, 2019Guru - Experienced User
Review the user manual for modem mode or NAT mode for the C3700 modem gateway. Disable the NAT mode and the modem will be in modem only mode.
Josephr9 wrote:I have a C3700 N600 Modem Router and would like to add the Orbi AC300 router. Do I need to set up the C3700 as a modem only? Or, can I just connect the Orbi directly to the C3700?
