dbandy's avatar
dbandy
Follower
Apr 30, 2020
Will Orbi RBR20 work with Nighthawk 6-Stream WiFi Router AX4300 Model#RAX45
I have successfully connected the Nighthawk AX6 6-Stream WiFi Router AX4300 Model# RAX45. (Just purchased today 4-30-2020 at Costco.)  Internet connection is established and working.  I also have an ...
  • FURRYe38's avatar
    Apr 30, 2020
    Orbi is not compatible with other non Orbi routers. They only connect to Orbi systems.
