Dazmae7
Mar 07, 2021Follower
Will Orbi RBR40 with 3 satellites work with Starlink modem
We upgraded to Starlink (satellite is our only internet option). Equipment arrived and is connected, signal active, I can connect to the internet through the Starlink router. But my Orbi RBR mesh with 3 satellites doesn’t seem to work when connected directly to the Starlink modem the way it did with our ViaSat modem and Hughes before that. Is it not compatible? What is compatible? We have a bigger home with thick walls and need range extenders.
1 Reply
try putting the netgear in access point mode.
The starlink receiver connects to its own router setup. so it puts you in a double nat (2 routers in router mode on the network)
