Lawandorder39
Jul 27, 2018Follower
Will Orbi RBR40 work with Windstream DSL
Hi, I’m trying to find out if the orbi mini WiFi will work with windstream DSL? We are showing connected but don’t have internet access and the lights are not staying solid blue. Should we use the Et...
Jul 27, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
