Amalfijohn
Mar 08, 2021Aspirant
will Orbi Tri-Band Business WiFi Outdoor Satellite (RBS50Y) AC3000 work with older orbi 2000
I want to extend coverage outside my home and think I read somewhere that the 3000 will not work with my older NETGEAR RBS20 AC2200 SYSTEM. I am trying to extend coverage to my pool sound isolation b...
CrimpOn
Mar 08, 2021Guru - Experienced User
Amalfijohn wrote:I want to extend coverage outside my home and think I read somewhere that the 3000 will not work with my older NETGEAR RBS20 AC2200 SYSTEM. I am trying to extend coverage to my pool sound isolation box that holds my external power points - but presently blocks off the signal from the house. Thank you.
Yes, the Orbi RBS50Y (outdoor) satellite integrates with all Orbi WiFi routers, including the RSR20.
The RBS50Y needs to have (a) electrical power and (b) a strong enough 5G WiFi signal to connect to one of the Orbi units inside the house.
Amalfijohn
many thanks for your response
