Amalfijohn
Mar 08, 2021Aspirant
will Orbi Tri-Band Business WiFi Outdoor Satellite (RBS50Y) AC3000 work with older orbi 2000
I want to extend coverage outside my home and think I read somewhere that the 3000 will not work with my older NETGEAR RBS20 AC2200 SYSTEM. I am trying to extend coverage to my pool sound isolation b...
mereen657856
Apr 06, 2021Aspirant
No i think its not possible but i will suggest you to try it may be it works for you and if you need some help then you can see some guidane on thispage and try hard for your tough task completion.
