Rsierra
Nov 14, 2020Aspirant
Will RBR20 work as a satellite on a RBR50 AC3000
Hi, I am looking to extend my signal. Will RBR20 work as a satellite on a RBR50 AC3000 network? Thank you
Nov 14, 2020Guru - Experienced User
No. RBRs only work as RBR in router or AP mode.
Rsierra
Nov 16, 2020Aspirant
Do you happen to know if the SRS60 AC3000 would work as a satellite with my RBR50 AC3000?
- FURRYe38Nov 16, 2020Guru - Experienced User
I don't. It's possible however the SRS series is the Orbi Pro line and may only be compatible with the Pro line Orbi systems. Something to ask out in the Orbi Pro forum:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-orbi-pro
