Supergate
Mar 27, 2019Aspirant
Will the Orbi system work together if I had the new NightHawk XR700/500 setup as a main router?
Will the Orbi RBR50 + 2 sats work if I had the new NightHawk XR700 or 500 setup as a main router? Basically I have the Orbi setup as a router now but I would like to have the nighthawk setup as the r...
Mar 27, 2019Guru - Experienced User
You can have to routers on the same network, however it's not recommended. You could use the XR routers DMZ for the Orbi if you wanted to run the Orbi as a router. I would disable the wifi on the XR router.
Or turn OFF the wifi on the XR router and configure the Orbi in AP modem, thus disabling the Orbis router and using the XR has the primary router.
Supergate wrote:
Will the Orbi RBR50 + 2 sats work if I had the new NightHawk XR700 or 500 setup as a main router? Basically I have the Orbi setup as a router now but I would like to have the nighthawk setup as the router and the Orbi system(router+2 sats) setup as the mesh wifi or extenders. Would that work?
