Supergate
Mar 27, 2019Aspirant
Will the Orbi system work together if I had the new NightHawk XR700/500 setup as a main router?
Will the Orbi RBR50 + 2 sats work if I had the new NightHawk XR700 or 500 setup as a main router? Basically I have the Orbi setup as a router now but I would like to have the nighthawk setup as the r...
Mar 27, 2019Guru - Experienced User
How many xbox consoles do you have?
uPnP is only needed. PF is not needed for xbox.
- SupergateMar 27, 2019Aspirant
I have (3) XboxOnes in the house and (1)PS4. The Cabem modem is an Arris CM3200.
- FURRYe38Mar 27, 2019Guru - Experienced User
Ok,
Since you nave more than one game console, set NAT Filter from Secure to OPEN.
This will help with two or more game consoles being online at the same time. If you play same game at the same time, this is needed.
https://badmodems.com/Forum/viewtopic.php?f=6&t=21
