Supergate
Mar 27, 2019Aspirant
Will the Orbi system work together if I had the new NightHawk XR700/500 setup as a main router?
Will the Orbi RBR50 + 2 sats work if I had the new NightHawk XR700 or 500 setup as a main router? Basically I have the Orbi setup as a router now but I would like to have the nighthawk setup as the r...
Mar 27, 2019Guru - Experienced User
How many xbox consoles do you have?
uPnP is only needed. PF is not needed for xbox.
Supergate
I have (3) XboxOnes in the house and (1)PS4. The Cabem modem is an Arris CM3200.
