b1uccy's avatar
b1uccy
Follower
Mar 01, 2024
Will the RBR20 / RBS20 pass through vlan tagging via wired backhaul path in AP mode?
So I have a wired router with vlans set up which connects to a managed switch. Into the managed switch I have my Orbi RBR20 connected in AP mode and then backhaul ethernet connected to the other side of the house to an Orbi RBS20. Everything works great, but I do have a smart TV connected to the second ethernet port of the RBS20. If I were to add a simple 5 port managed switch to the second ethernet port of the RBS20 would the ORBI work nicely with passing through vlan tags to this managed switch so I could put the smart TV on a seperate vlan?
No RepliesBe the first to reply
