zdbrad
Mar 30, 2020Aspirant
Will there be any issues connecting an RBK10 Satellite to an RBK50 router?
We've set up an RBK13 system, but it we cannot get a good signal to either of the Satellites from the Routers. It works OK if daisy chained, but its still only a 'fair' signal. We are very limited ...
michaelkenward
Mar 31, 2020Guru - Experienced User
zdbrad wrote:
I'm thinking of getting an RBK50... does anyone know if I can connect the RBR10 Satellites to the RBK50 Router?
Satellites work with whatever Orbi base station you throw them at. Some are more capable on the wifi front.
zdbrad
Mar 31, 2020Aspirant
Thanks for the info. I checked and the RBK50 is tri-band, where the rbr10 is dual band. I'm not sure if this indicates there may be issues, but it looks like I'll be giving it a try.
Thanks again for the help.
- FURRYe38Mar 31, 2020Guru - Experienced User
Let us know if it works. Dual band means that there will be no wireless back haul with the 1 series RBS. The 3rd radio on the 50 series is what this is used for.
