zdbrad
Mar 30, 2020Aspirant
Will there be any issues connecting an RBK10 Satellite to an RBK50 router?
We've set up an RBK13 system, but it we cannot get a good signal to either of the Satellites from the Routers. It works OK if daisy chained, but its still only a 'fair' signal. We are very limited ...
zdbrad
Mar 31, 2020Aspirant
Thanks for the info. I checked and the RBK50 is tri-band, where the rbr10 is dual band. I'm not sure if this indicates there may be issues, but it looks like I'll be giving it a try.
Thanks again for the help.
Mar 31, 2020Guru - Experienced User
Let us know if it works. Dual band means that there will be no wireless back haul with the 1 series RBS. The 3rd radio on the 50 series is what this is used for.
