Pableau_
Oct 21, 2019Aspirant
Will this Orbi setup work?
Hello, So, i'm thinking of buying the Orbi rbk23 micro. Was wondering if it's necessary to buy two sattelites or just one. So I live in a three story house but with one story in between that I don't...
Oct 21, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected
Pableau_
Thanks for the reply!
I don't use foot in my country, but according to google its 735 square ft.
Each floor in my house is about 3 meters high so it'll be about 7 meters which is less than 30 foot. The orbi would be directly above the other one, The walls are brick and the ceillings are wood.
Thanks!
- FURRYe38Oct 21, 2019Guru - Experienced User
Brick may cause problems. You'll have to test and set the satellites so that the signal reads good between them and the RBR.
Good luck.
