g8tors
Jun 24, 2018Follower
Windows 10 No Internet from Standby
When my Win 10 PC starts up from standby, the wireless connection shows Connected, but no Internet.
To get an Internet connection, I must disconnect and reconnect using the wireless icon in the...
Jun 24, 2018Guru - Experienced User
Whats the MFr and model # of this PC and thenetwork adatper card in side?
This wired or wireless PC?
You might look for power management options with in Windows and see if there is any thing you can change. Sounds like the adapter card isn't fully connecting after wake.
Set up a IP address reservation ON the router for this PC.
Do other devices have internet after waking?
