guardian-43
Sep 10, 2022Aspirant
Windows 11 VPN and Norton VPN
I got curious about the built-in VPN in Windows so I tried to configure it but it asks me for my VPN server address or IP. I am not even sure what the point is for the Windows VPN if you already have...
guardian-43
Sep 11, 2022Aspirant
Thanks CrimpOn,
So this now brings me to the Netgear Orbi VPN. I am starting to get the picture as far as the differences in VPNs'. Windows VPN and the Netgear VPN are for your network side and do nothing for external connections via secure tunnels other than allow you to connect to your network remotely (For the devices you have the VPN client installed/enabled on). The commercial VPVs' such as NordVPN provide a secure connection to the internet from whichever device you are using by connecting to VPN servers. So although they are all VPNs' they provide a different service, is that correct?
Thanks again.
- CrimpOnSep 11, 2022Guru - Experienced User
Correct
