Sookas63
Jun 15, 2018Aspirant
Windows 7 sees Orbi rbr50 as Gateway not Router
I just set up my Orbi but I'm having problems with my Windows 7 Broadcom NetLink Gigabit Ethernet connection. Windows 7 sees Orbi RBRK50 as Gateway not Router. The Orbi is in router mode not AP. Not ...
raven_au
Jun 16, 2018Virtuoso
Sookas63 wrote:
I just set up my Orbi but I'm having problems with my Windows 7 Broadcom NetLink Gigabit Ethernet connection. Windows 7 sees Orbi RBRK50 as Gateway not Router. The Orbi is in router mode not AP. Not sure if there are some settings that I need to change or what. My old ASUS system saw the ethernet cable connection but the Orbi doesn't. The PC is desktop and has no wifi connection.
I don't understand what the problem is?
It sounds like the Orbi should be seen as a Gateway (assuming I understand your meaning) in this configuration.
What isn't working for you?
How are you expecting it to work?
