ekhalil
Sep 16, 2018Master
Windows PC can't connect to wifi with DHCP
My work laptop (only Windows device at home) was working normaly until suddenly started to give me the triangle on the wifi symbol indicating no internet connection.
I tried changing many things in...
- Sep 16, 2018
What is the IP address pool set for on the router? Try setting it from default to 192.168.1.100 to 192.168.1.200.
Also do a IPCONFIG /release then IPCONFIG /flushdns then IPCONFIG /renew on the PC. Or fully reboot the PC.
Try using the Windows Diagnostic wizard for the connection and see if this will resolve the problem.
